Favorites Not Appearing
Hi all, I hope someone can point me in the right direction on this issue. I use a 3-tuner HDHR along with Apple TV4K's. When setting up the HDHR in the Channels app on the ATV's I remember going through the channel list and selecting Favorite, Visible, and Hide (or something very close to that). And when accessing the Guide on the ATV's this works great.
However, when I open Channels DVR Server on the PC, then choose Live TV, then Guide...there are 4 boxes near the top of the screen, which are all pull-down boxes: All Sources / HD / Today / Now
When I select the "HD" pull-down menu, then select "Favorites", no channels appear, the screen displays No Channels Match.
I thought my Favorites would appear here.
I hope I described the path accurately.
Really appreciate any help with this issue.
Bumping
Favorites in the web ui are selected separately from the Apple TV client favorites. You set the favorites for the web ui under settings, sources, pick a source, manage, manage lineup, heart the ones you want to show in the web ui favorites section. Fair warning though the dvr server uses favorites set in this “favorite” section as a priority to pick what channels it will use to record from. For example if you have a pass to record jeopardy and it is airing on both channel 10 and 15 and you have channel 10 favorited, the dvr will try to record from 10 first unless the pass specifically says to record from 15. If multiple are hearted it will choose to record from the highest channel number that is favorited. It is probably not a big deal as most people favorite channels that are reliable anyway but I just wanted to make sure you know that the favoring in the web ui does more than just adding them to the favorites section in the web ui guide.
