Feature request: Authentication for web UI
I was excited to access my Channels DVR over the web remotely until I realized there is no authentication required. If I open up the port on my router, my DVR is now exposed to the internet with nothing blocking anyone from accessing it.
I think adding some kind of authentication would be a very good idea.
Authentication is already built in. Try accessing the DVR remotely using an incognito window and you will see the login prompt.
Thanks, that did the trick!
