Enable a frame by frame advance/rewind using the top corners of the Siri remote touchpad.
After pausing playback, clicking on the right top edge of the Siri remote would do a single frame advance.
Clicking on the left top edge of the Siri remove would do a single frame rewind. Each click would advance or rewind by one frame.
Similarly, clicking and holding from either side would advance/rewind in slow motion until you release at which time it would pause on the frame at that point.
Aside: One way this could be used would be in conjunction with the existing “pause and scrub” functionality as a fine tune method. For example, you could begin the scrub by pausing and swiping, then when you get in the general area of interest, you could simply stop the swipe and click on the top sides of the remote in order to advance or rewind the playhead from that point, frame by frame.
