Feature Request: iOS beta versions in macOS Monterey on M1
I know Channels is not specifically supported on MacOS, but it's common knowledge that iOS apps (Including Channels DVR) run on M1 Macs. In the case of Channels, it runs perfectly!
Apple just added the Testflight app to MacOS Monterey, and I was hoping to run the beta versions on my M1 MacBook, but Testflight won't open the Channels iOS betas. Is there anything the Channels team can do to allow that, or is that purely an Apple restriction?
I'm guessing it's an Apple thing, but I thought I would ask. Thanks for the great product! The speed at which you innovate and update is unmatched.
Apple thing. Testflight on macOS is for macOS apps.
Thanks for the swift reply!
The beta is now available via TestFlight on Apple Silicon Macs.
