Feature request: recover from mid-stream feed switches in M3U recordings
Has anyone else seen this? On one M3U channel (a regional sports channel), the upstream feed switches a few minutes after the recording starts: the resolution changes (720p to 1080p) and the timestamps jump (the player shows about 10 hours of timeline for a 3-hour recording). The DVR log shows a single connection with no reconnects or errors.
After the switch, the audio is silent in VLC and distorted in Channels playback. The same stream plays fine live in TiviMate, which recovers on its own.
Workaround: start the recording 3 minutes late.
Request for the devs: could the recorder detect this kind of mid-stream change (resolution or codec change, timestamp discontinuity) and recover, for example by resetting or re-syncing the audio and normalizing the timestamps?
