Team,
Want to start of with a Thank you for all the hard work you put into Channels....I'm so glad I found it.
I need a little guidance on a few issues I'm experiencing...
Channels version 2021.11.09.1542
- I have a WD Mycloud and I've added a share as an additional storage path and though I can UNC directly to the share and play videos the Channels logs show an error that it can't open the share.
Storage Paths
\WDMyCloud\ChannelsDRV\ChannelsDRV-Playon-TVImport\ChannelsDVR.Extra
Failed to read directory \WDMyCloud\ChannelsDRV\ChannelsDRV-Playon-TVImport\ChannelsDVR.Extra: open \WDMyCloud\ChannelsDRV\ChannelsDRV-Playon-TVImport\ChannelsDVR.Extra: The specified server cannot perform the requested operation
- I have a virtual channel with a smart rule that selects TV Shows and Movies for content selection
but I've noticed when the order is set to custom, only Content (movies) can be re-arranged, not TV shows....is that working as designed ??.
Thanks for all do you...
