FFmpeg on DVR
FFmpeg flaw discovered
Open a sketchy video file in VLC, stream it using Jellyfin or Kodi, or don’t even open it at all – simply storing it can get you compromised when the Linux file manager generates a thumbnail.
I suppose someone's dvr can be compromised if they add a malicious mpeg that uses MagicYUV. Maybe quick fix is to just disable MagicYUV until you can test the new ffmpeg.
@maddox @tmm1 @eric
MagicYUV is not enabled in our ffmpeg builds.
it seems to be on mine...
dvr1$ cd ~channels
dvr1$ ls
2026.04.03.1854  2026.04.29.0232  2026.05.12.0935  2026.05.18.1824  2026.06.05.0615  2026.06.20.0022  data  etc  install.sh  latest  uninstall.sh
dvr1$ cd latest
dvr1$ ls
channels-dvr  comskip  ffmpeg  ffmpeg-dl  ffprobe  linux-x86_64.sha256  prerelease  version
dvr1$ ./ffmpeg -codecs | grep -i magic
 ..VI.S magicyuv             MagicYUV video
.. although
dvr1$ ffmpeg -decoders | grep -i magicyuv
dvr1$
not sure what it means to show up as codec but not decoder. i assume it means you're right it's not enabled
i actually checked with -codecs before making this post and didnt consider -decoders.
