Hi,
Trying to move my channels DVR from an old Mac mini to a NUC running Rocky Linux 9.5 (RHEL 9).
I've done the transfer OK and the server is running, so I thought I'd use my iPad to poke around.
I can watch existing recordings OK, and I can watch live TV via the HDHR, but my SAT-IP m3u is no longer working.
Looking in /var/log/messages I see:
kernel: ffmpeg[6614]: segfault at 63 ip 00007f388ab39794 sp 00007ffd42198130 error 4 in libc.so.6[7f388aa28000+175000] likely on CPU 6 (core 2, socket 0)
So switched back to the Mac mini and watched the same channel again (which works) and looked to see what the ffmpeg process was doing:
/Users/dave/Library/Application Support/ChannelsDVR/latest/ffmpeg -hide_banner -nostats -loglevel warning -rtsp_flags satip_raw -fflags discardcorrupt -copyts -probesize 8000000 -i satip://digibit-000f42.local/?src=1&freq=10788&pol=V&msys=dvbs2&mtype=8psk&sr=23000&fec=34&sid=10239&pmt=263&pids=0,5400,5401,5402,263 -enc_time_base -1 -max_muxing_queue_size 4096 -muxdelay 0 -ignore_unknown -map 0 -c copy -c:v copy -c:a copy -c:s copy -f data -
Running this by hand on the Linux NUC gives the same segmentation fault.
$ /opt/channels-dvr/latest/ffmpeg -hide_banner -nostats -loglevel warning -rtsp_flags satip_raw -fflags discardcorrupt -copyts -probesize 8000000 -i "satip://digibit-000f42.local/?src=1&freq=10788&pol=V&msys=dvbs2&mtype=8psk&sr=23000&fec=34&sid=10239&pmt=263&pids=0,5400,5401,5402,263" -enc_time_base -1 -max_muxing_queue_size 4096 -muxdelay 0 -ignore_unknown -map 0 -c copy -c:v copy -c:a copy -c:s copy -f data -
Segmentation fault (core dumped)
The ffmpeg binary works without any options.
$ /opt/channels-dvr/latest/ffmpeg -version
ffmpeg version 5.1.4 Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 6.5.0 (Ubuntu 6.5.0-2ubuntu1~14.04.1) 20181026
etc etc
Any ideas?
