Filter Recordings Only Web View?
Is there a way to only see recordings on the web view? Thanks in Advance.
DVR > Manage lets you filter Shows and Movies using the All Sources dropdown.
Also Library > Movies, but not Library > TV Shows
Is that what you meant?
Under Library/TV Shows in the Web view, I would like to see only recorded episodes.
Edit.. That did do the trick! Thanks!
