Is anyone else losing channels on fios? I can't scan Discovery, Food Network, DiY, ID and many others.
Even if I use a VPN I'm not getting anything.
Is this happening to others?
Only if I'm not on my wifi, which is why I thought the VPN trick would work. But it doesn't seem to be
Is it auto logging you on when you’re on your home network? That may be the issue.
