Firewall Setting Error Setting Message
I am getting a Firewall setting error message. The Windows firewall rule for Channels DVR is not enabled on all profiles. in a pink box. I checked and everything is set correctly. I had a problem last night and fixed it. Everything seems to be working Okay, but I am still getting the pink box with the The Windows firewall rule for Channels DVR is not enabled on all profiles. message.
Any ideas or help as to why?
So you’re saying if you look at all windows firewall profiles the channels rule is enabled?
Yes and everything is working Okay.
Can you share a screenshot of the windows firewall profiles showing the rule enabled?
This is outbound rules. Inbound rules are almost the same.
Yeah that all looks right to me. I would submit diagnostics from the DVR web ui and contact support to see if there is a bug happening maybe.
Thanks for the input. I guess I won't worry about it as everything is working correctly. By the way, I love the commercial skip feature. Well worth the price.
