Description of issue: When selecting actions for multiple episodes, the "Fix Incorrect Show" options is not available in v2
I expected: To be able to Fix Incorrect Show for individual and multiple selected episodes
What actually happened: Option not available, had to revert to v1
The show Reno 911, gives me problems because the later seasons that came out later are often listed as a separate show. Themoviedb has 3 separate shows, whereas thetvdb has the later 2 seasons apart of the main run (what I prefer, especially for virtual channels). I had noticed a gracenote entry shows 8 seasons, but season 7 matches incorrectly along side season 1. Not to make this a thread about that issue, but that's how I discovered the missing action.
