I have a tuner that is showing in the webpage with the wrong IP how can I delete the tuner and re-add it ?
HDHomeRun CONNECT (104162C4)
IP should be 10.0.0.223
Edit
Fixed itself.
Edit
Fixed itself.
You can click the gear and select Scan Network.
I would recommend you login to your router and setup a static dhcp lease for your hdhomerun so it's IP does not change.
Thanks that was what I was doing … Added a Synology router and put my Comcast modem/router in bridge mode that was the only tuner that I had trouble with .… now everything server/Tuners all have static IP's.
