I am getting this header when I go to my settings page:
Flow Control is enabled on 1 ethernet interfaces.
****Ethernet Flow Control is an outdated technology that can causes communication problems between the DVR and HDHomeRun, resulting in corrupted recordings. This is likely to happen if you use an Apple TV HD or other streaming device with a 100mbps ethernet connection. Newer Apple TV 4K devices use gigabit ethernet and are not affected by this issue.
1. Find the Channels DVR icon in the Windows System Tray
2. Right click the system tray icon
3. Click Fix Ethernet Settings in the menu
4. Click Yes in the User Access Controldialog
I did the fix Ethernet Settings and it greys out but nothing happens. I went to the adapter and checked flow control and it was off.
Is there anything else I need to do?
