Is the food network sending a higher quality stream via TVE? I have a low powered tablet, running the beta and it doesn't look like it can handle the stream.
Works fine on our PC's and Shields and OK on the tablet using Philo's UI.
The Food Network stream usually streams at 1080p @ ~5Mbps. (At least, a recording made this morning shows that.)
