Fox TVE with DTV Stream error
Getting this error when rescanning the source channel 6002 .
GET: https://api3.fox.com/v2.0/liveplayer/5836e01f3f93d90001ab6624?geoLatitude=40.3939&geoLongitude=-82.5566&epgListingId=WSYXDT3-program-WSYXDT3-1726495200000: 403 Forbidden: "{"@context":"http://www.w3.org/ns/hydra/context.jsonld","@type":"Error","n…":"Invalid AccessToken Key Id","detail":"Key Id not found or supported"}\n"
Maybe something changed with their contract dispute?
FOX TVE is very unstable.
The ability to watch will greatly depend on if you have a network owned fox station.
Agreed! Also tried with Hulu and Spectrum - same error about AccessToken Key.
Yeah...you're gonna have to forget about that. If you need FOX, then your best and reliable options is to get an antenna and HDHR or use CC4C or ah4c/hdmi encoder
The topic here is pinned
