M3U streams are always shared.
I did some comparisons and tweaking to my line
Added
tvc-guide-stationid="121307"
which seems to be correct for CST time zone
Removed
tvc-guide-title="Live weather"
which seems to have been overriding the guide data from the above
Found a jpg that I like better for tvg-logo=
Here's my new line:
#EXTM3U
#EXTINF:-1 channel-id="Fox Weather" channel-number="0.4" tvc-guide-stationid="121307" tvg-logo="https://static.foxnews.com/foxnews.com/content/uploads/2021/10/Fox-Weather-THUMB-SLIDE-3.jpg" tvg-name="FW",FOX WEATHER
https://247wlive.foxweather.com/stream/index.m3u8
Any updates on Fox Weather - Spectrum. Was working fine, but now shows "Failed to start stream for ch6725: TVE: missing video url."
I’ve got the same ongoing problem with Fox Weather using YTTV. And to worsen matters, the Weather Channel app on Fire TV sticks and cube (using Spectrum ISP credentials to log in) has crapped out totally. That’s not a Channels problem, but I’ve become suddenly weatherless.
@Suds just create a custom source and plug in the info from the picture 10 posts up and it will work.
…plug in the info from the picture 10 posts up and it will work.
I did exactly that and it worked like a charm. Thank you for that tip.
I’m wondering why this stopped working with YTTV credentials without having to jump through these hoops.
6725 Confirmed fixed on prerelease v2022.05.16.1458
