FOX (WHNS - Greensville, SC) & TVE Problem
Trying to setup my ChannelsDVR for our mountain cabin in Western NC. Switched from YTV on a RaspberryPI to a Synology DS220+ using Hulu, running the latest beta build (2022.11.23.1520). I'm able to get all the locals except FOX. On the Tvs using the app it gives a 403 error and when I try and scan the channel from the admin page, I get a 403 error next to the local fox station (6004) but I get Fox Sports and FX Channels no problem.
I did log into the Fox.com/live stream to confirm my credentials were working properly and did run the troubleshoot which showed the Chrome needed to be updated which I did a 2-3 days ago, but still cannot access FOX through channels. Any suggestions?
Submitted a problem log a few days ago but just submitted a new one to link to this post. d68ceda9-a414-4851-8da4-603853568c26
Thanks.
I’m getting the same 403 error on FOX only as well. I’m in centra NY.
Local stations through TV Everywhere is still experimental. ABC, CBS and NBC are currently working pretty good Fox is not. I currently can only get the Fox owned station in Atlanta for prime time network television outside those hours the channel is signed off. You may try rescanning at 8 or 9 tonight and you may be able to authorize. Just know it may drop again tomorrow. It’s more so a Fox thing than a channels thing right now as far as I understand it.
