Hi I have started to notice frame drop/skip when watching SD channels don’t think it’s happening on HD ones
Also if you leave tv playing for a few hours it seems to go out of sync
Any ideas
Any ideas
Questions: did you install the HDDPRIME update in the channels app, under settings from a few weeks ago?
Is your Apple TV wifi or wired? If wifi have you tried wired?
I did have a sync issue at the same time SiliconDust was having thumbnail issues. All the TVs in my house use the channels app through Apple TVs and they haven’t gone out of sync since SiliconDust fixed there issue with the last update.
Is your Apple TV set to 1080p 50hz, 1080p 60hz or Auto output? If you’re in the UK it needs to be set to 50hz for a smooth picture.
Hi Both i tried these but no luck, i reset my Apple tv and seems to be fine now, i had side loaded loads of apps etc since i got it so think it just needed a clean up
Thanks for your help
