Frndly TV for Channels
Just a thought about the "Stream Limit Reached" error...
I have the basic Frndly plan, which is only limited to one stream. I have only one recording scheduled at a time. However, I have them set to start 30 seconds before and end 30 seconds after.
In the past, this overlap hasn't been a problem. Is it possible that the Frndly is more aggressively enforcing the single stream limit for my account?
More likely is the setting you used
I have the Classic Plan w/2 streams and I hardly ever exceed that, so I have it set to no limit.
Could be the DNS server you use. Although I've seen that error occasionally on Frndly and Pluto channels.
Hmmm, that may very well be. Dang me for being honest in selecting my setting. I didn't realize that it would have an effect on the function of the service. Frndly is my sole source for Catchy Comedy.
I use Youtube TV and other services for most other channels, and one Frndly stream has always been sufficient up to this point. Even for overlapping programs on the same channel.
I'll try changing DNS servers... Thanks for the suggestion!
Run the Troubleshooting tool and see if it complains about it.
Channels DVR web admin UI
Support > Troubleshooting
No DNS issues there... all green checks, even with the resource intensive tests. :thinking:
Are you using your ISP's DNS Servers?
I use Cloudflare as Primary (1.1.1.1) and Secondary (1.0.0.1), no issues.
Yeah, I am using the default DNS servers from my ISP. It hasn't been an issue until recently.
Are you using Cloudflare DNS on your modem, router, and/or the device running your Channels server? My Channels server is native on Synology NAS.
I use Cloudflare DoH (DNS over HTTPS) on my router (Synology RT2600ac) and my router IP address is used as the DNS Server by everything on my network, including my two Synology NAS's.
Well, I switched the DNS on my router to Cloudflare, and still receive the same "Transcoder Reset: Playlist skipped to a higher sequence" errors when recording. Not always, but, occasionally. Most recently, on Pluto channel Classic TV Comedy.
The Synology NAS running Channels DVR is directly connected to the router by ethernet cable.
As I said previously
Maybe see it once or twice a month, but I don't record a lot from those sources.
Gotcha. As always, I appreciate your input. At least we know that neither of us is alone with these little glitches. :slightly_smiling_face:
I also see it once or twice a month. I record quite a lot off of Frndly and am always on the latest pre-release. Just saw it earlier this week on one recording. Using encrypted QuadDNS.
It seems to be independent of DNS. I have experimented with a few different options. I guess that it may be an issue coming from Frndly and/or Pluto. :man_shrugging:
Looks like FRNLY tv just added Cleo TV.
Gracenote id: 110289
Ohhh now this is news! Reelz is on barely ANY streaming services other than Peacock... it was the main reason I was trying to get CC4C to work. This makes that much easier.
Already showing up as a gracenote-exclude channel. @matthuisman I do believe the Reelz gracenote IDs are:
REELZ - 52199
REELZHD - 68385
Since I don't think there are EastCoast/WestCoast variants, I imagine that the 68385 should work just fine all around.
Or it might be one of these (type: Streaming) 121781, 119136, 117640, 113559, 123983
type: Cable Only name: Allied Telesis Reelz callSign: ATREELZ  stationId: 109161 video: HDTV logo:
type: Cable Only name: Oceanic Reelz        callSign: OCREELZ  stationId:  60584 video: SDTV logo:
type: Satellite  name: ReelzChannel         callSign: REELZ    stationId:  52199 video: SDTV logo: https://tmsimg.fancybits.co/assets/s52199_ll_h9_ac.png?w=360&h=270
type: Satellite  name: ReelzChannel HD      callSign: REELZHD  stationId:  68385 video: HDTV logo: https://tmsimg.fancybits.co/assets/s68385_ll_h9_ac.png?w=360&h=270
type: Streaming  name: REELZ                callSign: REELZSTR stationId: 121781 video: HDTV logo: https://tmsimg.fancybits.co/assets/s121781_ll_h15_ab.png?w=360&h=270
type: Streaming  name: REELZ                callSign: VIZREEL  stationId: 119136 video: HDTV logo:
type: Streaming  name: Reelz Channel        callSign: XALREEL  stationId: 117640 video: HDTV logo:
type: Streaming  name: Reelz Channel        callSign: XAZRLZ   stationId: 113559 video: HDTV logo: https://tmsimg.fancybits.co/assets/s52199_ll_h9_ac.png?w=360&h=270
type: Streaming  name: Reelz Channel        callSign: XCCRELZ  stationId: 123983 video: HDTV logo: https://tmsimg.fancybits.co/assets/s52199_ll_h9_ac.png?w=360&h=270
