Frndly TV for Channels
Info & Instructions
https://www.matthuisman.nz/2021/11/frndly-tv-for-channels.html
Source
https://github.com/matthuisman/frndlytv-for-channels
Support
https://www.matthuisman.nz/support-me
Frndly TV
Weather channel now gone
Non-Docker source for PlutoTV m3u playlists and EPG
Hallmark TVE Picture Quality
Please add game show network
Frndly TV Adds More Channels
Philo or Sling TV for Channels (like Frndly TV for Channels)
Hi all, Does anyone know if Channels works with Frndly?
TVE - Hallmark Channels low stream quality?
Custom Channels Master List *Update 5/12/23*
Slow death of ChannelsDVR for cable subscribers has begun
CC on Frndly TV
Provider - FuboTV
Eurosport
Frndly Timeout
LocalBTV support would be nice now that Locast is gone
Add GAC Family to the Channels App
YouTube TV - blocked by Google - almost fixed
The Dove Channel / Frndly TV
Provider - Hulu Live TV
Web player just sits there with a spinning circle
Backup or Rollover Channels
Frndly TV Enhancement
Frndly TV with Python on Windows without Docker: the easy way
Hallmark Stopped Working on TVE / Any Reccomendations For Other Services
Hauppauge and Directv stream metv tve
GAC Family included with Xfinity TV, but can I get it?
Would anyone help me add just one custom channel?
Python - FRNDLY - WEST Channel
Klowd TV
Hallmark TV app going away 3/31/26 - end of access via TVE?
REELZ - Fails to tune
The Weather Channel tve now available
Hallmark channel not loading since yesterday! - Xfinity NOW Provider
Some questions about YouTube TV
Hallmark on Philo TVE: Could not fetch playlist from crownmediaingest.akamaized.net 404 Not Found
Will ME-TV be availalbe
Writing dockers for Philo and other services
Problems with FrndlyTV
Which Sources/Content Support Captions (and which do not)
Custom Channels Question
I sent you $5 via PayPal. I love it when people make more stuff for channels dvr.
Sadly I've never tried friendly.
How many of its channels actually come through?
thank you :slight_smile:
they have 20x channels which all come through
I also sent you an email about Samsung (I already had done that yesterday):
Installed, seems to work great. Thank you so much, I have donated a bit! :slight_smile:
Awesome I'll do the Samsung tonight. I added it as custom channel. It works ok-ish. The guide is lackluster that way. I'm excited to have a docker for it
Omg I'm going to have so many channels
Pluto
Dish (family member)
Stirr
Pluto
Samsung (ill add tonight)
My guides going to take a hour to scroll through. Ty.
This is a great community
I have docker running on my MAC mini intel version and when I try to fire this up using your template from Github i get this error: -bash: !K: event not found
This is on the Frndly TV setup.
@matthuisman: That's cool, I can see all 20 Frndly TV channels in the guide now. :slight_smile:
However, I can't seem to find an EPG for it? Did I miss it?
I was waiting for that answer before I trialed it.
Nothing in the setup instructions about assigning an EPG source.
I think you need quotes around your PASSWORD=xxx, so -e "PASSWORD=xxx"
The epg should come in automatically if you leave the xmltv area blank. It uses station ids in the m3u to map the guide data.
Yes, it seems to be working now! :+1: :star_struck:
And now The Weather Channel is back in Channels DVR. Plus the Game Show network! Life is beautiful. :grin:
@matthuisman: your PayPal balance is about to increase slightly. :slight_smile:
5 posts were split to a new topic: Gracemote station id
How to set geo location for Local Now. I'm in Birmingham but getting Manhattan Weather.
A post was merged into an existing topic: Gracemote station id
oh right. I set an x-forward header to a USA ip address so the streams work everywhere.
I'll do an update soon to instead use your own IP address, but allow setting an IP via environment variable if users want a different location
UPDATE:
Done.
If you pull latest image - should now work using your real location
Default now is to use your own IP address.
If you want a different location or in a non supported region, you can set an IP environment variable for the IP you want it to use for your location
Readme has been updated
I tried that but it didn't work either :frowning:
Hm, try with single quotes maybe?
Or you'd need to pick a new password without a ! in it
I reset the password without any chars just letters and numbers and used the example from the last github post it looks like it tries to run but at the terminal prompt I see "dquote> " for some reason.
That means you started a " but didn't finish it.
