Fubo for Channels
Is this possible?
I have tried the Frndly TV for Channels running in Docker and it works well.
The problem with these streaming services is you can't get all the channels from TVE.
Probably not possible, given that these are likely fairly well locked down.
I use Fubo TV with Channels DVR by the built in TVE integration. Works fine, adds 165 channels.
A&E, FYI, History and Lifetime are DRM'd therefore will not work with channels. You will have to rely on your Cable or Streaming Provider for these networks.
Thanks for the feedback.
I use TVE and get most of the channels, it's just annoying that I can't get them all. Trying to eliminate the jumping back and forth between apps.
Channels DVR is a great product!
For what its worth, TVE via a subscriptions to DirecTV Stream does offer these channels. As does DirecTV, Dish, Spectrum and others. So they work in Channels, you just need to have a provider that allows you to authenticate them. Unfortunately Fubo isn't one of them currently.
Yep, current I am trialing DirecTV stream, in addition to my Fubo Sub.
Does anybody have any experience with TDS in regards to TVE?
I recently had TDS Fiber installed , but I didn't take a TV package. Maybe that was a mistake.
Those channels are available with other providers, but Fubo doesn't carry them at all. Nothing to do with TVE
Let's you see what channels are available with each provider.
Thank you I hadn't seen that. Very useful.
