Fubo TV project
I know, but is there a manual way to download it i want to reconfigure some channels are off?
Nope. Just edit the channel mappings in the settings
Ok thanks
Which channels are incorrect and I can see about correcting them in the script?
I just found this. I'm surprised it works as well as it does. I would have though everything was DRM'd. Apparently just Disney owned stuff is.
I've been doing the HDMI gig which works perfectly. This is almost instant tuning though. Debating using it for now.
I’m considering it now too. I cancelled Fubo awhile back but would consider rejoining if this is as good as it sounds.
So all of Fubo’s channels are accessible this way, even ones that don’t have TVE? Also wondering about NBC and MSNBC. I know they don’t carry Turner Networks (CNN, TNN and TNT) so those are off the table. Any other big name caveats?
Edit to add, I see the full list now. Wow! Thanks…
Yep,
Almost all the channels work.
I think what didn't work is on TVE yet.
Hmm? Can you rephrase this? Or provide an example channel affected?
Disney channels. Including freeform. Work on TVE, but not with the docker.
Edit: Can I add that DRM is dumb?
Bad for subscribers, good for piracy.
Looking for EPG for Lacrosse Sports Net.
Any Luck?
The stations that are not available at the moment are Disney (so ABC, Disney, ESPN, Freeform, and related so SEC, ACC, ESPN2 etc), Maximum Effort, Premium stations like Showtime and Starz (MGM is not DRM so it is available) and AT&T Sportsnet
I left the stations in the guide but they will not work with a msg in the log that the DRM field is true so will not attempt to play that station.
Outside of those channels others like NBC owned stations (SYFY, MSNBC, etc) are still working as Fubo does not have DRM on those stations yet
AT&T sportsnet doesnt have DRM. At least pittsburgh, and at least for a couple more days before the network changes hands
Thanks AT&T Rocky Mountain does
I don't know what I'm doing wrong, but no matter which I use I'm still getting the same error asking to set the user name and password
Help?
Thanks
Does your password include an exclamation point? Try changing your password to not include a exclamation mark
After I posted and doing some research that's the one I changed to not including any special characters. Sadly same issue
What do you mean "Try changing your password to not include a password"?
I think he meant "change your password to not include a symbol", just upper/lower case and numbers. Probably just a typo. I just did that, and it worked for me.
Bad news for sports fans in the Pacific Northwest: Root Sports Northwest cannot be tuned, so I'm guessing they have DRM on the channel. I was hopeful when I saw that other AT&T sports channels were working. I tested both the main channel and Root+.
AFAIK, that means there are no options for Root NW in Channels DVR.
Thanks for getting this set up though! It was pretty easy to configure and test.
That's what I thought just had to check lol I tired that with same issue, but I guess I'll try again when I can.
Thanks.
