Charlotte NC, local WBTV is incorrectly listed in the TVE listing. Should be WBTVDT, not WBTVFKDG
I'm here in California.
fubo TVE is showing 153 channels including 2 locals.
Fubo Docker is showing 267 channels. Disney content is hidden due to having DRM.
I'm on Elite Quarterly.
Was speaking to the WBTV, that is my local CBS on Fubo TVE, but the guide and listing carries it as WBTVFKDG it should be WBTVDT. Hence populating my guide with the wrong data. The Fubo docker has been mapped to the correct channel, but I'm afraid that is short lived. I can't seem to find the docker on the internet anymore. The docker has been great and my install still works, but afraid that is coming to an end since it seems to have disappeared. I hope I don't need a reinstall anytime soon.
Maybe one of the developers can fix it to use stationId 19603.
I don't know of a way we can correct it ourselves for a TVE channel.
You can always manually map the channel in CDVR
That doesn't work on TVE channels
Sorry didn’t read that part…what I’ve done is use two CDVR instances and feed one into the other as a custom M3U then map accordingly. This was typically done to set my own channel number but can also set the gracenote id
