Fxx issues
So I have noticed the Fxx channel has issues. A lot of times when I go the the channel I get a Ttimeout 32s”, but I can connect to live tv from the Fxx app no problems. Not sure if this is an channels issue or not. This has been going on for a while. Anyone else having a problem with that channel?
They are different streams. Instead of checking in the app, you need to check their website. Channels gets the streams from the network websites, which almost always is different than what they serve through their app.
Thanks I will check that out
