Gracenote Guide Data Issue
The DVR isn’t pulling guide data for all channels but if I select gracenote manually without the DVR enabled my Apple TV is able to pull all of the channel data.
Going to need more details than that… who is the provider, what channels are missing? If you click the pencil editor are you able to fix any of them?
HTC Cablevision Horry County Cable. All of the HD channels are missing along with a few SD. I can use the editor but it only gives me SD options, for example I could apply FX to FX-HD and get the guide data but that only works for the channels that also are broadcast in SD and may not be 100% accurate.
Please PM your zipcode
You need to re-enter your zipcode and pick the “HTC Cablevision Horry County - Digital” option so it includes the digital channels.
I tried that as well, I’ll run it again though
I see FXHD listed as channel 860 in the digital lineup.
Working, that’s odd though because I know I deleted it and ran digital this morning after it didn’t populate.
Yeah, I’m not sure why it didn’t pull this morning but I know I tried both, I even tried the two listed as “HTC Hospitality Legends Cable/Digital”. Its all there now though.
