Graphic overlay when captions is on?
It is indeed missing "Video Decoder"
Ya i see on the none bata version on my fire TV
I take offense to your tone. And for your edification, it has not been every post. You have created several threads, but I have commented upon less than half of them:
  • Why can't the app from the Play Store install the beta, which I did not comment upon.
  • Why was Comskip failing, which I did reply to with a link to the source code a specific reason for the error, which was later addressed by the developers.
  • A request that the guide data show proper info for time-shifted programs, which I commented upon and agreed with. Your request made it to the Apple clients, but I am not sure if the Android clients have this feature yet.
  • Bypassing the "Watch from Library" prompt, which I did not comment upon.
  • A "graphical glitch" from last September that seems quite similar to this instance, but which I did not comment upon.
  • Help regarding configuring a router/repeater; I contributed to this thread, and may have not been as helpful as you wished. However, looking at the posts, you were not very forthcoming with relevant data. It was also difficult as we had different vocabularies; further, it was not really related to Channels, per se.
  • Questions regarding commercial detection for in-progress recordings, which I did not comment upon.
No worries, I will just refrain from responding to your insufficient and hyperbolic posts in the future.
Thanks, please do. I don't want your kind of help. Thanks though :slight_smile:
I took offense to your tone too, many times already.
So i don't care if you're offended. Just dont respond to my (insufficient and hyperbolic) posts about my (cheap Amazon NoName) devices please.
Thanks
This is a community forum. If you need direct support from the developers, please email official support for the product at [email protected].
While we, the developers, are active in these forums, they are here for user to user support.
I already clarified that
And to clarify. No i didn't intend to personally message the developers alone, i am aware this is a community form, and I'd be happy to accept HELP from anyone here offering it. But not comments meant to put down, or make yourself feel big. Sorry but not me
The setting only appears on newer android versions. Please submit diagnostics from the stream+
Sure, will do that now
I just submitted diagnostics (for other) from the Stream÷
I see the new bata! THANKS.
Testing now
Ok, the video decoder setting in now back!
So i switched it to Software.
Not seeing the graphic glitch so far.
I'll keep testing it to see.
I appreciate the "HELP".
thanks
