Guide data download , how long does it take?
it's been like an hour and still seeing "Guide data is still downloading. Check back in a few minutes."
How long should it take ?
Does Support > Logs show it downloading, or some errors? Did you install fresh or restore backup?
Looks like I did not give it my zip code in the config page.... looks like its working now...
But the Whats coming on stuff works for a little bit then blanks out and says "It doesnt look like this channel has anything available " and "nothing seems to be on....later" even though the guide shows loaded and it shows stuff but only for a few seconds then blanks with that message... I have tried clearing cache , reloading guide data , open and closing app... not sure what to try next... this only happens in the appletv 4k app on my computer using chrome seems to be fine...
That's a bug. It should work better in TestFlight build. Can you try from getchannels.com/beta
testflight says it requires mac os 12.0 ... I'm running Mojave 10.14 ... (if needed by server side)
I put it on my appletv but I need a invitation code ?
Also I noticed on Firetv app there is no what's coming on section as well as clicking the network logo and seeing whats coming up... I was surprised by how different they are....
never got that email invite that apple requires.... thanks
