Guide Data Errors
I am now off of the SD DVR Beta. So I assume my Guide Data Source is coming from a different source then before. When I first started using the SD DVR Source there were similar errors and they fixed them. Is this a good place to report these or on the ATV Beta? Is all my Guide Data coming from the same place now? iOS, tvOS. Beta and not Beta?
Here is what I found so far. The #738 is the one my wife tells me about the most so if that could be fixed would be nice :slight_smile:
Frontier FIOS Pomona. 2x HDHomeRun Prime with CableCards.
#738 - "Up HD Channel does not show ICON, However, the correct ICON is on #659 for what is playing on #738. And #659 should be Enrich TV HD.
#629 - fyi. Showing current that is on Next.
#641 - LMN. Showing current that is on Next.
#691 - FXX HD Showing wrong show. Not even what is on next.
#697 - Viceland - No ICON - I do not watch it anyway but reporting.
There could be more.
Guide data for live tv still comes from SiliconDust. Nothing has changed there. On the Sertings tab on the ATV app it should show the SiliconDust logo.
It does. So I need to report it to them. Going forward will this change once you release the DVR?
Yes, Channels DVR will use its own guide data.
All good now. Nick was able to fix it pretty quickly. I wonder if they just reload the source or something like that. Anyway, just happy to have it fixed.
Great to hear! If anyone else has guide data issues, definitely reach out to [email protected]
