I noticed my Braves recordings were grabbing SD and I think it has to do with a guide data mismatch. Here you can see the SD/HD versions on two Fox Sports channels, but the HD version of FS Southeast has the wrong data and no logo.
Can you check if the same issue is present on https://tvlistings.zap2it.com, and if so, use the “Contact Us” link at the bottom of the page to report it.
Reported to them, anything else I should do? I tried to manually fix it and I guess I could remap the data to the SD version but I thought that may result in continued SD recordings.
Remapping the guide data should fix it. The recording will prefer the channel that is marked as HD on the hdhomerun.
