I am missing guide data on numerous channels. Any fix?
Open the dvr web UI and click the reload guide option
I did that with no resolution. About half of the channels have just the call sign (instead of the logo) and then just the call sign for the program guide, no program information.
Try re download entire guide.
You can also try clicking the circle refresh icon under your hdhomerun which will load missing mappings from SiliconDust's app.
Still not fixed.
It's as though the lineup is corrupt from the provider's end. Here's one of the channels with missing data. The channel itself is missing...
Go to the QNAP apps interface and stop/restart the dvr from there.
Thank you. That did it!
