San Diego OTA 10.5 Bounce guide data is 3 hours off in Channels. It is accurate in the HDHomerun app. I clicked the sync station mapping and redownloaded the guide but it didn't change anything. It appears that this is the only channel that is off. Any suggestions?
Hmm is there a logo for that channel in the HDHR app?
Yes the Bounce logo is there.
Is the guide data correct for the channel on zap2it.com ?
If it is, try changing the guide mapping to KGTVDT5
Should be station id 118806
The guide data is incorrect on zap2it by the same 3 hour difference. It's like it's eastern feed or something. I wonder why HDHomerun has it right in their app? Thank you for your help.
Can you report it on zap2it using the contact link at the bottom of the page
Until zap2it fixes it you can remap the channel to use guide data from 34.3 KMEXDT3 station id 92056
I reported it. I will try to remap using that station. Thank you both for your help.
