My Guide data only goes out about 6 hours on the web UI,
24 hours. on the client.. now after rebooting everything it's about 6 hrs.
When I check the logs I see this for XUMO
2026/01/13 14:53:53.846931 [DVR] Reindexed 13527 airings into XMLTV-xumo (379 channels over 34h0m0s) + 9968 skipped [7s index]
Does this limit all Guide data for ALL my sources to apprx 34 hours?
I am on the latest pre-release, for Win 11.
Earlier today I deleted and recreated the Guide database.
On the UI it is also limited but if I Select Today at 90pm or tomorrow it shows guide data, but again limited to a day or so.
24 hrs on the client sounds right for an HDHR tuner if the client can't connect to the DVR server.
What sources do you have setup in your Channels DVR Server?
NO
Check the web UI guide and select each source to see how far out each source has guide data for.
Also check the DVR log to see if any errors getting guide data for each of your sources.
Thanks for the suggestions.
I don't see any issues with Clients connecting to the Sever,else nothing would work, no messages.
I have many Sources, some are test sources to try to pull in channels outside of my Cox Source, like XUMO.
I don't use containers etc, just M3U playlists.
When I go to the Guide in the UI for All Sources,
the Guide data stops for all sources at about the exact same spot,
the only exception is long movies or long shows that may extend another hour or so.
I'm going to Disable al Sources except HDHR, check the Guide, then add Sources one by one,
BUT you are saying encountering a Source with short Guide data will not limit ALL the rest.
I tried updating EPG every 6 hours on all the Sources, but not much change.
So I'm still at a loss.
UPDATE: In a nutshell, Disabled all Sources, re-enabled one by one, so far all is good.!!
All Sources disabled except for HDHR.
Reloaded HDHR guide data.
Logs show it does 14 days.
Web UI shows 6 hours on iPhone,
Channels app on iPhone shows Full guide, all days.
Client shows full guide, all days.
Added Cox Source.
Force stop and clear cache on Client.
Full guide on Client.
Added XUMO source.
iPhone channels app, 6 hours for Xumo and Cox.
Client seems OK for Cox. XUMO only 30 hours or so, as expected.
Added a few more Sources one by one.
Client seems OK.
Will add more Sources one by one LATER, to see if the Guide cuts off again.
I would use a PC web browser to view the DVR web UI Guide. Are you viewing it in Safari on your iPhone?
That would be a client
Which client, your iPhone?
You just said your Cox source showed full guide on client. Which client?
Which client?
Confusing when you say client in one sentence and iPhone in another.
Your iPhone is a Channels client. Do you have other Channels clients?
When looking at the Guide in the DVR web UI, pick one source at a time so you can see how many days of guide data you have for just that source you select.
Sorry, for me Client means my Onn Pro. but of course App on phone is a Client. My bad.
What I've seen is that for instance, if the first channel in the App on phone or Onn is a short one like XUMO
it cuts off at 30 hours or so as expected, and the other channels do also... did not investigate this closely
I could be wrong.
Yes Safari for Web UI on phone, and with that I can scroll to the right to see how many days.
As for looking at Guide in Web UI and picking one source,
I do that on laptop Web UI but don't see how to scroll to the right to see how many days, as i can do on the phone..
I can use the Today, and Now or pick a time and that does work, it's what I've been using to set a recording a week or so away.
But again, all seems OK now, fingers crossed.
Thanks for the help.
