Hi-using the experimental local channels. The guide doesn’t match up with the programming. The NBC channel says it’s the local channel but the programming is several hours off. All the other channels are also several hours off. I think they’re central time (Dallas) though I’m in Portland. NBC has the Portland station call name but has the later programming as well.
Are you using a VPN or DNS provider than your ISP's? When you enabled local channels via TVE were you accessing your DVR server via HTTPS?
If all your guide info is off, check your DVR server, may need to set the correct timezone on it.
It’s on PST
Ahh I had reset the channels and they seemed right but were off when I looked this evening. I had a vpn going set to Texas-so I think nbc is fixed. Thanks!
