Guide Navigation - Enter Channel Number
I currently use Channels on AppleTV, and I'm thinking about switching to a NUC. I'm trying out Android Channels on my Windows 11 desktop and it seems to work OK. I'll need to get used to navigation/UI differences. One thing I did notice was I couldn't change channels by typing in the channel number, which can be done on the AppleTV with a remote that has channel number input. Any chance of that getting added to the Android version? Scrolling through the guide when you have a lot of channels gets tedious.
This might be because you are getting the Android interface, not the Android TV interface. On Android TV devices numeric input is indeed available.
Ok. Didn't know there was a difference between the Android and Android TV UI. Thanks!
