Guide not behaving
I'm having an interesting problem that I've seen in other posts, but my issue doesn't seem to be exactly the same. My guide is showing duplicates in a way. For example, in the Android app on my Nvidia Shield, on channel 5.1 (Fox in NY) it's showing Fox News Sunday with Chris Wallace for the period 10:00-11:00, which is correct. However, it's showing the same thing for the period 11:00-12:00. At that time there is supposed to be a Cindy Crawford infomercial. This is also happening on other channels (e.g. Decades, ABC CBS), but not all. I'm using Locast. Though the same happens if I enable my HDHomerun. Now that it's 10:30, the guide is showing Fox News Sunday with Chris Wallace for the period 10:30-11:00 as well as 11:00-11:30.
This also happens on the guide when I access the DVR sever via a browser. When I choose "All Sources" it's funky. When I just choose "Locast" it's fine. On the guide in the Android App, it doesn't matter what I choose. The guide is always funky. I've refreshed the guide on the server. I've quit and restarted the app. I've enabled and disabled sources. And so on. I've checked the guides in the HDHomerun app as well as on the Locast website and they are correct.
Also, the guide data for the Pluto for Channels and Stirr for Channels docker containers routinely disappear. I'll be watching something and go back into the guide and the data is gone. The guide just shows a long, dark purple liine with the channel name (e.g Rifftrax).
That happens to me when I add locast. haven't figured out how to fix it...
The only way I got around is under Locast settings uncheck use OTA Numbers. It does not combine the lineups properly when using OTA numbers.
