I've been playing around with the Virtual Channels feature. First off let me comment what a great feature this is. Also thank you for taking a look and fixing the various issues I have come across with this feature.
After getting my issues fixed, I finally got the Virtual Channels working the way I wanted. Basically, I am creating a separate channel for each of the TV shows I have in my TV show collection. This works great.
I have come across one unexpected thing though. When viewing the virtual channels via a guide, each episode is listed first with the show title and then on a second line with the episode title. If I look at the guide in the web interface it looks as follows:
This looks good. However, when looking at the guide on one of my clients, the room for the guide is a lot less so it only displays the first line. This makes it look like this:
It is only displaying the show title and not the episode title. At first, I thought this might be some type of bug, but then when looking at the guide for normal non-virtual channels from other sources (OTV, TVE), I realized this is normal. Normally a channel doesn't just show one show so it makes sense that it would display what show is currently on. However, with virtual channels since a big use case is for exactly what I am doing, which is dedicating a channel per show, it would make a lot more sense to show the episode title on the first line (or the only line) instead of showing the show title. We obviously know what show is on that virtual channel based on the virtual channel name/graphic, so there is no need to show the show title in the guide.
For virtual channels, is there currently a way to get the guide to just show the episode title instead of the show title? If not, can an option be added to virtual channels to default to episode title instead of show title? Ideally, we would be able to set this setting per virtual channel since some channels may show multiple shows (for example my BBC Earth channel in above screenshots). If you would like for me to post this over in feature request please let me know.
