I don’t know how far ahead the guide is supposed to go but it’s like it gets stuck or something.
If you subscribe to the dvr, you will get a much longer guide, downoaded from guide provider.
SiliconDust provides 4 hours of guide data. As @djcastaldo mentioned, combined with Channes DVR it can have up to 21 days of guide data.
Channels DVR support will come later in the year.
OK Thanks
@tmm1 Is the DVR pushing extended guide data to the shield yet? I have the DVR and am still only getting the standard 4 hours.
- Thanks
Not yet.
This has been added in the latest beta (build 46). Install via https://play.google.com/apps/testing/com.getchannels.app
Is this the same version as when one updates the Channels DVR (Nvidia) thru the web UI?
There are two apps: one is the DVR server and the other is the client. This update is for the client.
