Does this app just pull the channel data from the HD Homerun software or can I edit ie map channel data to certain channels?
Reason I ask is that I’m using clear qam on Verizon FIOS due to OTA reception issues with a couple of locals, and they get channel numbers in the 5000’s. The HD Homerun software doesn’t have any guide data for them because of this. Just wanted to check before spending the money. Thanks.
