On the web interface, I would like the ability to pick a time on the guide (e.g. primetime such as 8:00 PM), and then easily move across days without the guide time reverting back to the time selected in the drop down (e.g. 6:00 PM). I do this for scanning for shows (usually during primetime hours) that I might be interested in recording.
I see two possible ways this would work:
- Is it possible to have the time dropdown provide an entry for every hour?
- Can the guide stay at the time it has been scrolled to as you switch the days using the drop down (e.g. if I select today and 6:00 PM, manually scroll the guide to 8:00 PM using the mouse, and then select tomorrow then the guide should should tomorrow at 8:00 PM and not move the time back to 6:00 PM).
