Guide update interval times possible not saving
I'm on pre-release 2021.3.26.0045 running on windows and I noticed that with all of my custom channels m3u playlist sources when I click on the gear icon then edit settings then at the bottom for xmltv guide data when I change it to refresh every 3 hours and click save then go back in it's always set back to refresh daily. Does anyone know if it's actually saving the change setting to every 3 hours and it's just a bug that it switches back to daily or is it actually broken?
Fixed in next prerelease
Let me know if it works now.
Awesome it appears to be fixed now, at least for me thanks!
Yes I can also confirm that it's now fixed. Thanks.
