HACK: Use Channels DVR as a Plex tuner
That is not good I thought it would only pull EPG of Channels in the Collection.
Yeah, one of the things I noticed when trying to import M3U into Plex is how long it takes for it to sync up the guide. Would hope that a smaller XML file would help.
The issue is that EPGs are per Source (right now), and your Channel Collections can have channels across multiple sources, so the only real way to guarantee guide data, is to use the EPG URL for all channels.
OK, that makes sense.
At least for those who still want to limit the download size, every bit helps, so they should consider setting the EPG duration for one week instead of two weeks, to cut the size in half:
https://xxxxxxxxxxx.u.channelsdvr.net:8089/devices/ANY/guide/xmltv?duration=604800
...or even less, like 6 hours (21600 seconds) if they're just using it to surf live TV.
I've followed the steps in post 2 to install the codec on my mac and I'm still getting S1001 error. Note that the folder that is shown was not present, but /e613bce-3d5ad59c62e771ae9cb5738e-darwin-x86_64 was. i downloaded it there, no luck. I created the folder in the post and put it there as well. No luck. Non-TVE plays fine, but TVE gives the error. This is an Intel mac if it makes a difference. Perhaps a different codec file is needed for Intel mac?
You have to go into the folder that is present and then make a url that has the same code as that folder.
Did that, same outcome
The file you downloaded is only 472 bytes, so its not correct.
The url doesn't match the pattern I provided earlier.
curl -O https://downloads.plex.tv/codecs/e613bce-38cf5cd1fd57f37d2412c608/darwin-aarch64-standard/libaac_decoder.dylib
vs
curl -O https://downloads.plex.tv/codecs/e613bce-3d5ad59c62e771ae9cb5738e-darwin-x86_64/libaac_decoder.dylib
What you need to use is:
curl -O https://downloads.plex.tv/codecs/e613bce-3d5ad59c62e771ae9cb5738e/darwin-x86_64-standard/libaac_decoder.dylib
Looking back at my terminal history, I did try that format, but with the same result. However, removing the 472 byte version and running your code fixed the issue. Thanks.
@maddox Just wanted to make sure you saw this before - virtual channels are getting passed through on custom channels to plex
In the M3U or the EPG?
It's supposed to be filtered out of the "ALL" M3U, but probably not each individual one.
m3u
Has anyone figured out how to add Channels DVR as multiple tuners to Plex? From my testing it really only sees it one time and you can’t add another one from the same IP address.
I’d like to have separate channels collections show as separate tuners over on Plex but it doesn’t seem to work.
That didn't work for me either. I considered creating one combined Channel Collection that I would use specifically with Plex, but I was so turned off by the rest of the user interface that I just abandoned ship.
Actually if Plex allowed groupings by channels then it would be a non-issue for me. I know they do it for their own channels based on their metadata but I don’t want them deciding for me lol.
Hi Guys, I don't like to post but can't seem to get it to work, Wont let me add the URL http://127.0.0.1:8089/devices/ANY/channels.m3u that's one from Channels (i tried with correct IP and i tried with other URL with added ?formatt=ts etc none work i could find.
Do i need one Tuner to be active before it works, Running latest pre-release of channels also,
Is it still working or broken on Plex Side
On your Sources Web Page there is a setting to copy the M3U and EPG
This is the link i tried http://192.1.1.1:8089/devices/ANY/channels.m3u
No Dice
Why don't you do as I posted above don't really care what you tried if it didn't work.... You are probably on an old release of Channels DVR.
What is the version number?
