Yes. You must click-and-hold the update button
Thank you very much I was unaware of holding the update button, with the latest version and rescanning of channels I am back in business.
Updated to the latest but these channels are still not working.
You have to rescan them via the pencil icon and EDIT button after the upgrade
Channels are working again. Could there be something added to the DVR Server to periodically check for broken links and notify somewhere that these URL's are broken so we can do a re-scan to fix them.
Even better, if it finds broken links then automatically re-scan...
I'm having the same problem. I just upgraded to the 2020.10.11.2246 build and rescanned all my channels but I still get errors for the hallmark channels. It appears that the issue is that Hallmark's URLs have changed. The links on their own website are still broken. I found the updated URL structure. The following link is for the standard Hallmark channel:
Able to reproduce here. Will fix for next build.
Just fixed it by whitelisting the watchhallmarktv.com url in NextDNS. It was blocking it because it was a newly registered domain.
