Hi,
I have a recurring problem for the past month or so where playback just hangs when I try to skip forward, back, or use "Skip Commercial". This happens both on Android TV and through the web player. It does not seem to be specific to any particular channel or program, and it only happens after Channels has been up for several days. It started last month and has continued this month both with regular releases and pre-releases.
The stall will sometimes catch up if I'm patient and let the app sit there for a few minutes (the further I seek, the longer it takes). If I try to skip again, the lag will once again kick in. Once the problem occurs, it happens for any recording from any channel and for any seek in any direction. Force stopping the app on Android TV (NVidia Shield Tube), clearing cache, etc have no effect. Obviously, those don't apply to the web player.
Restarting the Channels server seems to temporarily fix the issue, but it will recur given sufficient time. I'm running Channels Server 2024.09.12.1557 on Win11 23H2.
I submitted diag logs ac3704a2-5cc0-408a-93e3-a04507069d4c last night.
