Hard drive - which to connect to?
Should I connect the hard drive which has the DVR files to my computer where the Channels app is or to the router? Which performs better? I’m guess directly to the computer?
You never want the storage seperate if you can. It just adds to the bandwidth and latency. That’s why they give us so many install options.
Okay, thanks. I’ll continue to have it hooked directly to my computer.
