Hi, could someone please clarify for me that if i move my movies folder to a different, bigger hard drive will i have to match them up on the moviedb or gracenotes again
Just backup DB before move ... and when you move the recordings do a larger drive do a restore from it and everything will be good,
Channels Support - How do I move Channels DVR Server to a new computer?
If they're recorded by Channels DVR in its Movies folder, and you move the directory structure to the new drive and restore from the most recent backup, they will come over.
If they're Imported, you will have to rematch them.
Unless those Imported Movies are in the Channels DVR created Imports/Movies folder.
If you use cloning software to clone the old drive to the new one and then assign the new drive the same drive letter, or mount depending on OS, all will be wonderful after you restart.
