Hardware Transcode help
linux debian
trixie/sid (kernel: 6.17.0-35-generic)
CPU
16 cores / AMD Ryzen 7 5700U with Radeon Graphics
64 GB Ram
curl -XPOST http://127.0.0.1:8089/hls/hwaccel
Running this does not show any response in the logs what so ever. Any suggestions? Trying to get hardware working instead of software only.
Your best bet is to install a low end Nvidia chipset PCIe GPU. Used ones are very inexpensive.
Thanks but it's a mini PC so what I have is what I have. No add on slots but I would think it should still show some sign in the logs.
It wont. It just does a Rescan Hardware.
What does this show in your browser?
Should be same info as View Debug Info
Screenshot 2026-06-17 at 16-39-58 Channels Settings
AMD GPU support is experimental and hit and miss and the requirements say this. Possibly there is a driver you can load. You may find better support in Windows. Then enable Hyper V and run a Linux VM if needed.
Yes it does show the debug info. @tmm1 perhaps you could takea look, I know it will hardware transcode but just not with the builtin version.
