Hardware transcoding fails
Nvidia 2070 super passes Hardware testing but fails to transcode in web UI and remote viewing. Diags submitted as e74b1fc2-fe5e-440c-814f-3086440d6aec and here is a small log sample.
 2025/05/19 18:56:41.293065 [ENC] Starting encoder for ch6001 in F:\DVR-storage\DVR\Streaming\ch6001-dTVE-Comcast_SSO-e322bcb183c6-3734813249\encoder-6-1789135666 at 6 (8.204767) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=720, deinterlacer=hardware, bitrate=5871, segment_size=0.01)
2025/05/19 18:56:41.346509 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [vost#0:0/h264_nvenc @ 000001f590fe6d40] -enc_time_base -1 is deprecated, use -enc_timebase demux
2025/05/19 18:56:41.441666 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001f5a41561c0] decoder->cvdl->cuvidCreateDecoder(&decoder->decoder, params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
2025/05/19 18:56:41.441666 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001f5a41561c0] Using more than 32 (33) decode surfaces might cause nvdec to fail.
2025/05/19 18:56:41.441666 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001f5a41561c0] Try lowering the amount of threads. Using 16 right now.
2025/05/19 18:56:41.441666 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001f5a41561c0] Failed setup for format cuda: hwaccel initialisation returned error.
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Failed to negotiate pixel format between 'graph 0 input from stream 0:0' and 'auto_scale_0':
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      graph 0 input from stream 0:0 (buffer)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      auto_scale_0 (scale)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p, yuyv422, rgb24 (+183 more)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ⚠️ hwupload needed ⚠️
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ cuda
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      Parsed_yadif_cuda_0 (yadif_cuda) [requires cuda]
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ cuda
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      Parsed_scale_cuda_1 (scale_cuda) [requires cuda]
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p, nv12, p010le (+13 more)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      format
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p, nv12, p010le (+13 more)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p, yuyv422, rgb24 (+227 more)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      out_0_0 (buffersink)
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Impossible to convert between the formats supported by the filter 'graph 0 input from stream 0:0' and the filter 'auto_scale_0'
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [vf#0:0 @ 000001f58e7bd5c0] Error reinitializing filters!
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Failed to inject frame into filter network: Function not implemented
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Error while filtering: Function not implemented
2025/05/19 18:56:41.453966 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [out#0/hls @ 000001f5911cbb00] Nothing was written into output file, because at least one of its streams received no packets.
2025/05/19 18:56:41.559879 [ENC] Encoder stopped for ch6001 in F:\DVR-storage\DVR\Streaming\ch6001-dTVE-Comcast_SSO-e322bcb183c6-3734813249\encoder-6-1789135666 after starting from 6 without encoding any segments
2025/05/19 18:56:41.563846 [ENC] Starting encoder for ch6001 in F:\DVR-storage\DVR\Streaming\ch6001-dTVE-Comcast_SSO-e322bcb183c6-3734813249\encoder-6-58250480 at 6 (8.204767) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=720, deinterlacer=hardware, bitrate=5871, segment_size=0.01)
2025/05/19 18:56:41.614683 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [vost#0:0/h264_nvenc @ 0000017686d1ed40] -enc_time_base -1 is deprecated, use -enc_timebase demux
2025/05/19 18:56:41.717568 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001769a24aec0] decoder->cvdl->cuvidCreateDecoder(&decoder->decoder, params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
2025/05/19 18:56:41.717568 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001769a24aec0] Using more than 32 (33) decode surfaces might cause nvdec to fail.
2025/05/19 18:56:41.717568 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001769a24aec0] Try lowering the amount of threads. Using 16 right now.
2025/05/19 18:56:41.717568 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001769a24aec0] Failed setup for format cuda: hwaccel initialisation returned error.
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Failed to negotiate pixel format between 'graph 0 input from stream 0:0' and 'auto_scale_0':
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      graph 0 input from stream 0:0 (buffer)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      auto_scale_0 (scale)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p, yuyv422, rgb24 (+183 more)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ⚠️ hwupload needed ⚠️
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ cuda
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      Parsed_yadif_cuda_0 (yadif_cuda) [requires cuda]
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ cuda
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      Parsed_scale_cuda_1 (scale_cuda) [requires cuda]
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p, nv12, p010le (+13 more)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      format
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p, nv12, p010le (+13 more)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p, yuyv422, rgb24 (+227 more)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      out_0_0 (buffersink)
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Impossible to convert between the formats supported by the filter 'graph 0 input from stream 0:0' and the filter 'auto_scale_0'
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [vf#0:0 @ 00000176848dea80] Error reinitializing filters!
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Failed to inject frame into filter network: Function not implemented
2025/05/19 18:56:41.729816 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Error while filtering: Function not implemented
2025/05/19 18:56:41.730322 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-5-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [out#0/hls @ 0000017686f35ec0] Nothing was written into output file, because at least one of its streams received no packets.
2025/05/19 18:56:41.763135 [ENC] Encoder stopped for ch6001 in F:\DVR-storage\DVR\Streaming\ch6001-dTVE-Comcast_SSO-e322bcb183c6-3734813249\encoder-6-58250480 after starting from 6 without encoding any segments. Marked segment as failed.
2025/05/19 18:56:43.483881 [ENC] Starting encoder for ch6001 in F:\DVR-storage\DVR\Streaming\ch6001-dTVE-Comcast_SSO-e322bcb183c6-3734813249\encoder-7-1836278725 at 7 (10.243678) (encoder=h264_nvenc, codec=h264, acodec=copy, resolution=720, deinterlacer=hardware, bitrate=5871, segment_size=0.01)
2025/05/19 18:56:43.532589 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [vost#0:0/h264_nvenc @ 000001aafd8e6900] -enc_time_base -1 is deprecated, use -enc_timebase demux
2025/05/19 18:56:43.622145 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001aa93317040] decoder->cvdl->cuvidCreateDecoder(&decoder->decoder, params) failed -> CUDA_ERROR_INVALID_VALUE: invalid argument
2025/05/19 18:56:43.622145 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001aa93317040] Using more than 32 (33) decode surfaces might cause nvdec to fail.
2025/05/19 18:56:43.622145 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001aa93317040] Try lowering the amount of threads. Using 16 right now.
2025/05/19 18:56:43.622145 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [h264 @ 000001aa93317040] Failed setup for format cuda: hwaccel initialisation returned error.
2025/05/19 18:56:43.633751 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Failed to negotiate pixel format between 'graph 0 input from stream 0:0' and 'auto_scale_0':
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      graph 0 input from stream 0:0 (buffer)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      auto_scale_0 (scale)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p, yuyv422, rgb24 (+183 more)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ⚠️ hwupload needed ⚠️
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ cuda
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      Parsed_yadif_cuda_0 (yadif_cuda) [requires cuda]
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ cuda
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      Parsed_scale_cuda_1 (scale_cuda) [requires cuda]
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p, nv12, p010le (+13 more)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      format
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↓ yuv420p, nv12, p010le (+13 more)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      ↑ yuv420p, yuyv422, rgb24 (+227 more)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:      out_0_0 (buffersink)
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Impossible to convert between the formats supported by the filter 'graph 0 input from stream 0:0' and the filter 'auto_scale_0'
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [vf#0:0 @ 000001aafd870300] Error reinitializing filters!
2025/05/19 18:56:43.634394 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Failed to inject frame into filter network: Function not implemented
2025/05/19 18:56:43.634901 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  Error while filtering: Function not implemented
2025/05/19 18:56:43.634901 [HLS] ffmpeg: ch6001-dTVE-Comcast_SSO-e322bcb183c6-6-h264-copy-copy--5871-0-720-0-0--hardware-false-false-0.01-0:  [out#0/hls @ 000001aaffc8ee80] Nothing was written into output file, because at least one of its streams received no packets.
2025/05/19 18:56:43.759787 [ENC] Encoder stopped for ch6001 in F:\DVR-storage\DVR\Streaming\ch6001-dTVE-Comcast_SSO-e322bcb183c6-3734813249\encoder-7-1836278725 after starting from 7 without encoding any segments
Anything else needed just let me know.
and 32GB of ram
