Hardware Transcoding not working on MeLE Quieter 3Q
Continuing the discussion from New Beelink U59 not transcoding:
Rather than hijack the Beelink U59 thread, I figured would start a new thread. I decided to shift my Channels DVR server from the Beeline U59 to a MeLE Quieter 3Q running Ubuntu. Unfortunately, I again am having issues with hardware encoding. Specs on the new server are:
MeLE Quieter 3Q
Intel(R) Celeron(R) N5105 @ 2.00GHz
Ubuntu 24.04.1 LTS
Channels version: 2024.12.10.0055
The Hardware Transcoder Probe states that both vaapi+deint and vaapi@/dev/dri/renderD128 are successful.
I tired the echo "options i915 enable_guc=2" | sudo tee /etc/modprobe.d/i915.conf command from the U59 post, but that did not resolve the issue. The error I am seeing is a little different than before.
2024/12/23 12:13:23.993705 [ENC] Starting encoder for ch4.1 in /home/mapeter01/channels-dvr/Streaming/ch4.1-dANY-c3af85556081-942253601/encoder-4-3553457019 at 4 (3.576300) (encoder=hevc_vaapi, codec=hevc, acodec=aac, resolution=720, deinterlacer=hardware, bitrate=3616, segment_size=0.01)
2024/12/23 12:13:24.169014 [HLS] ffmpeg: ch4.1-dANY-c3af85556081-3-hevc-aac-copy--3616-192-720-0-0---false-false-0.01-0:  [hls @ 0x3fb97ec0] Stream HEVC is not hvc1, you should use tag:v hvc1 to set it.
2024/12/23 12:13:24.189246 [HLS] ffmpeg: ch4.1-dANY-c3af85556081-3-hevc-aac-copy--3616-192-720-0-0---false-false-0.01-0:  [hevc_vaapi @ 0x3fc2f540] Failed to end picture encode issue: 24 (internal encoding error).
2024/12/23 12:13:24.189278 [HLS] ffmpeg: ch4.1-dANY-c3af85556081-3-hevc-aac-copy--3616-192-720-0-0---false-false-0.01-0:  [hevc_vaapi @ 0x3fc2f540] Encode failed: -5.
2024/12/23 12:13:24.189280 [HLS] ffmpeg: ch4.1-dANY-c3af85556081-3-hevc-aac-copy--3616-192-720-0-0---false-false-0.01-0:  Video encoding failed: Input/output error
2024/12/23 12:13:24.194084 [HLS] ffmpeg: ch4.1-dANY-c3af85556081-3-hevc-aac-copy--3616-192-720-0-0---false-false-0.01-0:  [aac @ 0x3fc256c0] 2 frames left in the queue on closing
2024/12/23 12:13:24.194142 [HLS] ffmpeg: ch4.1-dANY-c3af85556081-3-hevc-aac-copy--3616-192-720-0-0---false-false-0.01-0:  [aac @ 0x3fc26940] 2 frames left in the queue on closing
2024/12/23 12:13:24.369705 [ENC] Encoder stopped for ch4.1 in /home/mapeter01/channels-dvr/Streaming/ch4.1-dANY-c3af85556081-942253601/encoder-4-3553457019 after starting from 4 without encoding any segments
Any help would be appreciated.
What if you disable the experimental hevc setting?
I forgot I had checked that option. It is working now. Thanks for the help.
