How do you program a last channel button on the Harmony remotes?
IR or hub/BT-based?
For hub/BT remotes, the remote is paired as a keyboard, and the Backspace key is set for the previous channel feature.
For IR remotes, you can either use one of the color buttons (RBYG) and set it up in Channels' settings, or assign it to a macro of Play Play, since double-pressing the play button acts as last-channel, too.
